| Item | Action | Item Price | Quantity | Total |
| Amazon Fire HD 10 Tablet, Quad-core, Fire OS, 10.1", Wi-Fi, 16GB, Silver | Collection * | -£169.95 | 1 | -£169.95 |
| Lenovo Yoga TAB3 10, Qualcomm APQ8009, Android, Wi-Fi, 2GB RAM, 16GB, 10.1" HD, Black | Delivery: Standard delivery within 5 working days *** | £179.95 | 1 | £179.95 |
| Total | £10.00 |
Not an expensive fixDaughters is a fire but the usb port has give up as most makes do.
Sounds interesting - but access denied for UKMy likely purchase is
Here in Thailand 6,400 baht is £155 or so
Has good specs including a sim card slot
OKSounds interesting - but access denied for UK
| Brand | Lenovo |
| Model | Tab M10 TB-X605LC |
| Processor | Qualcomm Snapdragon 450 (8C, 8x A53 @ 1.8GHz) |
| GPU | Integrated Qualcomm Adreno 506 GPU |
| Ram | 4GB Soldered |
| Rom | 64GB eMMC |
| Memory card | MicroSD card (Up to 256GB) |
| Display | 10.1 "IPS 320nits |
| Resolution | 1920x1200 (FHD) |
| Front Camera | Front 5.0MP |
| Back Camera | Rear 8.0MP |
| I / O Interfaces | Micro USB |
| Audio | Dual front speakers with Dolby Atoms / single microphone, 3.5mm combo audio / microphone jack |
| Network | 802.11 a / b / g / n / ac, 1x1, dual-band (2.4GHz & 5GHz) |
| Bluetooth | Ver 4.2 |
| 2G | UMTS: B1 / 2/5/8, B1 / 8 (801LV) |
| 3G | FDD-LTE: B1 / 3/5/7/8/19/20/26, B1 / 3/8 (801LV) |
| 4G | TDD-LTE: B38 / 39/40/41, B41 (801LV) |
| Sensor | G-sensor L-sensor |
| Satellite Map System (GPS) | ROW: GPS + GLONASS; PRC: GPS + Beidou |
| Operating System | Android Pie |
| Battery | 7000mAh |
| SIM | single Nano-SIM card |
| Function calls. | None |
Something to be aware of (and is getting quite common) ... The SIM slot is shared with the SD Card slot - so it is an either/or option you can use, but you cannot have both installed at the same time.My likely purchase is
Ok thanks, Good to know.Something to be aware of (and is getting quite common) ... The SIM slot is shared with the SD Card slot - so it is an either/or option you can use, but you cannot have both installed at the same time.
My phone is like that.. install a 2nd SIM OR a Micro-SD.
It is not clear at all, you are right, but in the diagram showing all the connections #3 (I think it was) is shown for both devices.Ok thanks, Good to know.
My phone has 2 sim cards and Memory
I will tether the tablet to my phone (ALMOST 100%) SO the sim card is of little use to me
It might be used in an emergency..but unlikely
My reading of the spec is not clear as to whether the slot is ONLY for one or the other
Yes the Memory card is essential for data but I have seen other similar tablets with no Sim card
Not a worry
Yes 1 slot only....extra memory suits meSomething to be aware of (and is getting quite common) ... The SIM slot is shared with the SD Card slot - so it is an either/or option you can use, but you cannot have both installed at the same time.
