Deleted member 1906
The auto selector can cause problems. I think there is a delay so that if you are on battery and pull in for fuel the gas does not spark up as soon as you switch the engine off.
We always use manual selection......................even then when changing source to gas we have to leave it switched off for a while.I guess the delay function still kicks in.
As said keep the burner area clean, but also we find it sometimes needs a rap on gas regulator or solenoid which can stick and stop the gas coming through when required.......trace the gas pipe back from the burner
