I think we can probably stay awake until then!Hi it’s ‘Two plus Woo’ here. Is it ok to arrive around 9 pm tonight? Adrian &Julie
Hi, think as we are likely to arrive so late, we will stay at Abbotsbury, so you can enjoy your evening. Is that ok with you?Hi it’s ‘Two plus Woo’ here. Is it ok to arrive around 9 pm tonight? Adrian &Julie
Whatever works for you, you’re not the only ones coming in late!Hi, think as we are likely to arrive so late, we will stay at Abbotsbury, so you can enjoy your evening. Is that ok with you?
It’s a huge field so plenty of space. Thanks for letting us know and hope you can make itHey, sorry for late notice but a family drama means I’m not going to be able to make this meet. I had hoped to postpone arrival but I’m not even sure if that will be possible. Is there a reserve list? If so I’ll drop out completely so somebody else may be able to take my space… otherwise I’ll try to make it for a couple of days if I can. I hope you all have a great time.
rogerRight Folks!
The man from the RAC has been and the general consensus is that there was a problem with the fuel temperature sensor which was recording 100 degrees Centigrade and the EGR valve needs replacing.
It turned out that the fts was unplugged so that was an easy fix, but the EGR valve has had to be ordered and is coming tomorrow.
It’s a relatively simple job, just three bolts, however they are quite awkward to access, so we could be looking at a Test Drive early afternoon. If all is well, we could arrive early Friday evening. FINGERS CROSSED EVERYBODY!
