shortcircuit
Puraclean for me. If Truma advise against a Milton type fluid why would you use it when other alternatives are available?
I have always used coca-cola I just put 5lta bottle into the tank drive around for 25 minuets then flush it out with clean water never had any problems with it.
I find that’s great for grey waste tanks, but perhaps it would taint water tanks,
I use Elsan Fresh Water Tank Cleaner, £7.99 for 1litre, which will do me two cleans.
Mrs GMJ has a lowered immune system and tends to pick up stomach bugs etc and as its her who uses the shower on board I thought I'd give it a go.
Thanks, Graham. Good tip about the grey water tank. I'll leave that overnight for a clean; although we do tend to use a separate bowl for the washing up water so that it can be emptied immediately after the Grey Tank began to stink to high heaven!I never leave mine for the full 12 hours Steve tbh. Haven't died yet
Do you drink the water from your on board fresh water tanks? We only use it for washing, showering and dishes. If you don't drink it then I think you will have probably covered it with the one cleansing tbh but no problem with a 'belt and braces' approach though.
One thing which you may well have covered but I decant the sterilized water into my grey tank and leave it in there for a few hours so it gives that a bit of a clean too.
Unsurprisingly, I take a more cautious approach! I top up the water in the sink and shower traps [have to do the same with our French hovel!] and, periodically [i.e. when I remember or the smells recur], I flush some warm water solution mixed with washing up liquid and then rinse through with fresh waterWe always decant into a flexible bucket and dispose of it appropriately so no tank niffs for us either. The only thing that can niff is the plug holes but a good dose of Mr Muscle sink unblocker every now and then, sorts that.
