Burge
Same hereOnce Iāve filled the tank I run it through the pipes and taps before leaving it. I also make sure the hot water tank is full.
Like you Rog I open the hot taps first then the cold.As a side note, when you refill your water tank after a draindown, always open all the hot water taps first. This will ensure that the boiler is filled. Then open the cold taps to complete the operation.
