NopeAll a waste of time, few towels under the screen is best, you cannot suck the damp out of the whole world, well GB anyway.
Not really as more air enters with water in it so back to the start again, unless of course you keep the heat on 24/7, letting it cool makes it worse as the air/water content condenses on cold surfaces, back to the start again.Nope
BUT you can reduce humidity levels to a less damaging point .
I'd agree with that IF you were sat with all the windows and roof vent open .Not really as more air enters with water in it so back to the start again, unless of course you keep the heat on 24/7, letting it cool makes it worse as the air/water content condenses on cold surfaces, back to the start again.![]()
And the air you suck water out of with a condensing unit will fill the van again unless you keep it in a vacuum, dont mater what you close the air comes in through heater ducts and small gaps on the under side of the f doors, best thing is move to spain lol.I'd agree with that IF you were sat with all the windows and roof vent open .
However in normal circumstances it's perfectly possible to reduce the humidity levels to a point where it doesn't condense on cold surfaces .
Using a rotary dessicant humidifier is also far more efficient than trying to heat the air up .
If you have a heat source to create circulation then part of that process is cool damp air will enter to take the place of the warm damp air that has convected out .
OK you win Trev .....And the air you suck water out of with a condensing unit will fill the van again unless you keep it in a vacuum, dont mater what you close the air comes in through heater ducts and small gaps on the under side of the f doors, best thing is move to spain lol.
Im not trying to win anything, just pointing out a fact, what folk wish to do is up to them.OK you win Trev .....
I only work day in and day out in aircon and ventilation humidity and temp control.
Don’t know if it does any good, but I have an ultrasonic pest repeller plugged in in my van.A word of warning, 2 years ago when energy was less expensive, I kept a low level of heating on, in my van, the local mice took advantage of my generosity and set up home !
Resulting in a chewed through Truma control cable, (and that's the only wiring that I have identified so far!)
Plus stored food stuff, pasta, cereal, biscuits, chocolate and various food packets !
Little Nipper took out 8 before the Great Spring migration!
We had the little buggers invade the kitchen in the Flat, entering the Garden from an overgrown bank adjoining the rear lane, By the time we traced the entrance point, the killing tally exceeded 40 [43 IIRC] including some that had made it into the Lounge and into the underside of the upstairs Flat staircase! And then the rats arrived in the garden from the same bank ... Quite impressive to see how far the trap flies with a rat suspended in the jaws!A word of warning, 2 years ago when energy was less expensive, I kept a low level of heating on, in my van, the local mice took advantage of my generosity and set up home !
