Fifer
I personally feel that it is wrong that there are free charging points for ev. We are all paying expensive charges for electric at the moment, so why not charge ev users. Why should those owners get it for free? If it is such a small amount to pay for charging , ev users, don't be so mean & just pay! It is annoying to hear ev owners, in general news terms, moan about having to pay to charge their vehicles. I say, don't be so tight!Thanks Wildebus, a lot of research went into it so I’m pretty proud of the kit.
Just like everything. Each supplier has its own charging rates and some charge 50p per hour plus the KW charge and that too is set by the supplier.
Now I have used Tesco chargers as they charge 28p per KW or part thereof, the cheapest I got charged was 2p. But in Scotland, I charged overnight and was charged £1.88 to a full charge.
I have 540AH, so that is around 7300KW, so the most I’ll ever be charged is £2.05
I have also found a place near Aldridge which is 4 hours of free parking and the charge points are free too.
It's pretty simple though, you download the app that the charge point uses, (Tesco uses PodPoint), and follow the instructions. The only reason I like using Tesco or Pod Point is that I don't want to have to top up credit on a number of various apps.
Using your example of the 70W Multiplus, you will be able to charge your batteries at roughly 1KW an hour, this actually means you still have 2KW free to run down the cable, so using an air-fryer, microwave, or kettle while charging is also possible. As the cable can do 13A at 240V so just over 3000W.
All I can suggest is to read the signs and familiarise yourself with the terms and conditions of the parking.
Best regards,
Bruce
