As far as I can tell, so far anyway. There doesn’t seem anything wrong with the product . Apart from dire instruction booklet. Not forgetting those rubbish cables. Please don’t use them. Jeff is happy with 35mm on his 2000w inverter, and I’ve used 50mm with my 3000w. And for goodness sake, use an appropriate fuse..I researched and Renology had excellent right up/reviews; and I've got a solar panel but no invertor.
When it comes to inverters, go thick!As far as I can tell, so far anyway. There doesn’t seem anything wrong with the product . Apart from dire instruction booklet. Not forgetting those rubbish cables. Please don’t use them. Jeff is happy with 35mm on his 2000w inverter, and I’ve used 50mm with my 3000w. And for goodness sake, use an appropriate fuse..
Yeah mine are welding cables as well David .When it comes to inverters, go thick!
I used my 2400W inverter (on the Multiplus 12/3000) and I found even the 50mm cables got quite warm and changed to 70mm - and this was a run of only around 750mm long from battery bank to device.
(I'm using the 35mm cable that Victron supplied with my current Multiplus 12/1600 (which is a 1350W inverter) and that is fine, but they do supply decent cable (it is actually marked "Welding Cable", which is ideal for using with an Inverter)).
I was just thinking about that as I scrolled down the discussion.
'And remember, viewers, if you can't get welding cables, you'll just have to solder on ...', as Hughie Green ought to have saidYeah mine are welding cables as well David
Is that a brazen attempt at humour? Flux that!'And remember, viewers, if you can't get welding cables, you'll just have to solder on ...', as Hughie Green ought to have said.
