Trotter
The idea of fitting a domestic fridge to Demi is still going around my head.
One I’ve looked at has a Annual consumption of 106kwh.
Using this:- kWh x 1000 divided by 8700 ( rounded up hours in a year ) = watts
If I’ve got this right, 106 annual kWh is a little over 12wh.
But that figure would be @ 240v. So 12wh x 12 volts = 20watt minimum inverter.
There’s a 3000w inverter in Demi. Because of the 2w drain it has, a smaller inverter would be an better alternative.
