Exwindsurfer
Oi referee!! You only said a couple of questionsHmm, might help Liz so a couple of questions.
- Where from it comes?
- A picture do you have of the ends?
- What size is it?
A couple most strictly means two, but it's often used casually to mean much the same thing as a few, which commonly means around two, three, or fourOi referee!! You only said a couple of questions
It's from Ebay it is 550mm long and I think 85mm high the ends have a 8mm holes to bolt it on .Hmm, might help Liz so a couple of questions.
- What size is it?
depends if it is a mormon "couple"A couple most strictly means two, but it's often used casually to mean much the same thing as a few, which commonly means around two, three, or four
I think this is the product you used, Jeff? Grab Handle for MotorhomeThe seller is securefixdirect
Won’t be long Jeff when a ramp will be required, one that is zimmer friendlyBeen meaning to do this for a long time anyway new rail turn up today so it started off being a bit of a bugger but ended up not a bad job .Now it's great getting in and out the van and all for 14 quid.View attachment 68649View attachment 68650
All the questions I wanted to ask could really do with one on my van.Hmm, might help Liz so a couple of questions.
- What size is it?
You could be right TerryWon’t be long Jeff when a ramp will be required, one that is zimmer friendly![]()
For 14 quid Annie you carnt be robbed.All the questions I wanted to ask could really do with one on my van.
I will look into getting one fitted.For 14 quid Annie you carnt be robbed.
The comedian, Jo Caulfield, does a lovely routine about an elderly relative who was an Irish Nun, but decides to liaise with a man after she retired. 'Well, you'll have to take me from behind so that I can still balance on my Zimmer Frame while we're doing it ...'Won’t be long Jeff when a ramp will be required, one that is zimmer friendly![]()
