Complete set of Spanners, Pliers, Cutters, etc, for the mechanical type stuff ...Just curiouswhat tools do you carry onboard?
Need more clues, Gordon; I'm guessing it involves a long'ish passage where the light fades rapidly and the stench grows to overpowering rather quickly, and where the odd roll of lino can be found ...I know where the sledgehammer is going to be put
You've seen the photo of all the tools I carry with me and will likely never use.... and you have just come up with a situation where I would be stuckI'm hoping we carry one of those little glasses repair kits you get in Christmas crackers, as the screw has just fallen out of my reading glasses onto the floor of the cab.![]()
You'd still be stuck, David; because, whilst you've got your glasses off to make the repair, you wouldn't be able to see well enough to make the repair ...You've seen the photo of all the tools I carry with me and will likely never use.... and you have just come up with a situation where I would be stuck
Time to add ANOTHER set of screwdrivers in the kit![]()
Never left home without my little kit (and needed it a couple of times over the years). But then I tried tightening the screws and putting a drop of Loctite on the underside of the screw. Problem solved.I'm hoping we carry one of those little glasses repair kits you get in Christmas crackers, as the screw has just fallen out of my reading glasses onto the floor of the cab.![]()
I have an old ratcheting screw driver set with bits which includes sockets from 7 to 13 and the equivalent in inch fractions. The same with the allen keysAhh but do you have a 10mm socket.
My tool bag is 50% rust think there’s a plough and an old cranking handle for a tractor in there somewhere.
Phill found the screw. He loves a challenge. I found a screwdriver on my non-Victorinox Swiss Army knife copy. The tiny one with a plastic handle that screws into the corkscrew - sorted.Never left home without my little kit (and needed it a couple of times over the years). But then I tried tightening the screws and putting a drop of Loctite on the underside of the screw. Problem solved.
Edited to add: One of these is also a must in order to find the lost screw. https://www.amazon.co.uk/Blue-Spot-...hvlocphy=&hvtargid=pla-4584482456222403&psc=1
