Wrighpm
Hi my lead acid batteries now drop to low voltage very quickly and are needing replacements. They are currently both attached to the motorhome charger in parallel.
I only use for lights, water pump and Truma heater fan. The two existing batteries owe me nothing so happy to replace.
My first question is when having two batteries do they charge adequately attached in parallel from the manufacturers original charger?
My second question is ... are AGM batteries significantly better than lead-acid. (cannot afford Lithium)?
I was thinking 2x 100AH AGM from Alpha batteries.
Any advice most welcome.
Also 100W solar is attached to the above.
