I have heard various things about Crashdata. If it solves the problem, good. But if the fault comes back, you are back to square one and their service has zero guarantee so money paid so far is gone and wasted.It's said that you shouldn't start the motor until all the warning lights extinguish.
We I used to do that.
But eventually I got the percentage air bag light on permanently.
You can get the ECU ( It's under the passenger foot well) repaired at a company called Crashdata.
But I chose to have a new ECU installed. Local Fiat professional dealer wanted £1000 plus. So instead I used Essenjay of Poole- a lot cheaper but still painful.
Anyway they fitted a new one which interestingly has a different product code when compared to older ECU. Also they said that since using the newer versions they had not had any "returns". You can draw your own conclusions but I know what think about Fiat's suppliers of the original ECU!!
Is that £1000 for an ECU that just does the airbags???
I would blank the bulb and if that wasn’t acceptable fit a timer on feed to/from it to the bulb
The testers are wise to this 'workaround' (depending on the competence/diligence of the individualIs that £1000 for an ECU that just does the airbags???
Removing and replacing the ECU is fairly simple.The quote from Fiat was supply & fitting the ecu. As said Essenjay were cheaper.
Apparently there is another company who also repair the ECU via post - both companies provide instructions how to access and remove the ECU. Me, well I'm not faint hearted, but I'd rather someone competent to delve into that sort of area.
I suppose my only retort to "blanking" the indicator light with an indicator powered in " series" is that (as I understand it) that if an air bag is fitted then it must pass an MOT inspection.
Interesting. I had seen comments about guarantee lasts until you get the unit fitted, so good to hear otherwiseI Had mine done by Crash Test data and they guarantee it for life.
Quick turn around about £70 and about 3 days from posting to them. I know at least a dozen people who have used them without a problem. Spoke to someone who used fiat for same problem they had van for a few weeks at a cost of more than £500. Seem there’s an inbuilt fault usually appears around 2 3 years old.
hi its a MOT failure .cheyenneThe quote from Fiat was supply & fitting the ecu. As said Essenjay were cheaper.
