Most 3 way fridges use about 120w on 12v and about 150w on 240v. BUT on 12v there is usually no thermostat, it uses 120w 24/7, it's just intended for use whilst driving only. On 240v there is a thermostat so its not 24/7 but at 150w its about 3 times as much power as a compressor fridge.
Need to factor both the power use when runnng and the duty cycle to get a good comparison
A 3-Way Fridge from being switched off takes a full day to get down to safe operating temperature. That is 24 hours of running constantly.
A Compressor Fridge takes around 1-2 hours to get down to the same temperature. that is a 10th of the time and at a lower power consumption per hour.
So that is the first factor.
This aspect is important when it comes to people who go off on intermittant and spontaneous trips - with a 3-Way, you might leave the fridge on all the time just in case. With a compressor fridge, if it is empty, no need to leave it on using power as you only have to switch it on a couple of hours before you need it.
Once running, both types of fridge do have on/off duty cycles, but a 3-Way fridge is on for longer than a Compressor fridge in any given time period.
Duty Cycle of a typical 3-Way Fridge running on AC
(just click on the red X if no image appears. Flickr playing up)
3-Way - AC Daytime by
David, on Flickr
Duty cycle of Compressor Fridge for same time duration (10AM to 4PM)
Compressor Fridge - AC Daytime by
David, on Flickr
So comparing the two fridges, you see when drawing power runnng on AC, the 3-Way is taking over 3 times the wattage of the Compressor Fridge
Maybe the newest 3-ways are 120W + 150W, but tend to be higher as per the photo below of mine.
Thetford 3-Way Electric Power by
David, on Flickr
200W on AC vs around 55W for the Compressor Fridge.
Factor in the duty cycles and I calculated that the typical 3-Way Fridge used SEVEN times more power than a modern Compressor Fridge. And it doesn't matter if it is AC or DC for that difference. 240V Compressor Fridges actually tend to be slightly more efficient than 12C DC ones; include the inverter overhead and it switches around but either way very little to choose between 12V and 240V.
You see people complaining about not being able to run a Compressor Fridge off their battery bank (and you typically need 200Ah I reckon to avoid having to go into silly fridge power-saving routines)?
If that is the case, what kind of battery pack is needed to run a 3-Way on AC full-time when off-grid? It really is not worth it.
If you have enough spare electric to run a 3-way on AC for any extended duration, consider using that power to do your cooking with electricity, or use the electric element in your water heater. These are far better and efficient uses of spare electricity than an highly inefficient absorption fridge and by doing that you will likely save more gas than you would trying to use the Fridge on electric.
(FWIW, I have my Motorhome setup so if the battery gets to a certain SOC, off-grid AC Power is provided to the Truma Water Boiler, so any excess solar gets put to use that way. That adds up to around 850Wh of Power. That is not massively short of what a 3-Way Fridge would use on AC in a day. But if the boiler heated the water on the LPG, I think it would use more gas than the Fridge would in a day?)
