runnach
MMA or Mags, Jeff?My very first time at welding Terry thank god it’s not seen lolol
75 quid mig welder of Ebay lololMMA or Mags, Jeff?
Ah OK, was MAGS aka Metal Active Gas Shielded. MIG aka Metal Inert Gas ( Shielded) MIG welding is used to weld aluminium, which required Pure Argon, an inert gas. If MAGS welding, this is normally Low Carbon Steel, or Stainless Steel. Copy paste for explanation of gas mix.75 quid mig welder of Ebay lolol
Flux core, Jeff. ALDI/LIDL stuff is fine for certain projects, and did what you required, and satisfactory. But I would not be hanging my washing on anything nailed by them cheap machines!!View attachment 71591tryed it with thin plate as well
mine is flux core lololAh OK, was MAGS aka Metal Active Gas Shielded. MIG aka Metal Inert Gas ( Shielded) MIG welding is used to weld aluminium, which required Pure Argon, an inert gas. If MAGS welding, this is normally Low Carbon Steel, or Stainless Steel. Copy paste for explanation of gas mix.
MAG stands for Metal Active Gas. Active gas mixtures have been developed primarily for welding steels. Typical shielding gases are mixtures of argon, carbon dioxide and oxygen e.g. CO2 , Ar + 2 to 5% O2 , Ar + 5 to 25% CO2 and Ar + 10% CO2 + 5% O 2 .
Now you have been edumacated Jeffrey, you will sleep tonight....................did I mention flux core? LOL
This can do the trick Jeff, just dont sit on itmine is flux core lolol
I got a £60 stick welder from Aldi many years ago, thought it would be rubbish but needed something quick. Turned out to be a great little welder, stuck a couple of trikes together even with my pidgin shite weld lolThis can do the trick Jeff, just dont sit on it![]()
I have had my 140 amp stick welders for decades and still work's well. I bought new from a rep who supplied the company I worked for at the time with our welding consumables, I paid £40. Has got me out the bit a few times.I got a £60 stick welder from Aldi many years ago, thought it would be rubbish but needed something quick. Turned out to be a great little welder, stuck a couple of trikes together even with my pidgin shite weld lol
Thank goodness for flap wheels![]()
Very true Neil lolololI got a £60 stick welder from Aldi many years ago, thought it would be rubbish but needed something quick. Turned out to be a great little welder, stuck a couple of trikes together even with my pidgin shite weld lol
Jeff and Neil, during my induction to new group starting my welding evening class, went as follows "after 12 weeks, you will either be a good welder or a good grinder"Very true Neil lololol
OR, if you become a good grindr, it could be a typo or an inclination; if the former, it may encourage a trial welding run in the boxer shorts area before leaning forward at the welding bench ...Jeff and Neil, during my induction to new group starting my welding evening class, went as follows "after 12 weeks, you will either be a good welder or a good grinder"![]()
Oh No please tell me you are not registered with Grindr, Steve?OR, if you become a good grindr, it could be a typo or an inclination; if the former, it may encourage a trial welding run in the boxer shaorts area before leaning forward at the welding bench ...
Isn't Grindr a Gay dating App LOL. Whoops!OR, if you become a good grindr, it could be a typo or an inclination; if the former, it may encourage a trial welding run in the boxer shorts area before leaning forward at the welding bench ...
Naw, just a typo, Terry ...Oh No please tell me you are not registered with Grindr, Steve?![]()
You are what you eat, Steve.Naw, just a typo, Terry ...
Is that an offer?Or munch, Terry ...
