Sonar
You can buy fitted cab carpet on Ebay too.A ready made rubber mat bought from the well known auction site made the cab look nice and tidy a lot better tahn the i dont know what floor that was there.
not my cup of tea to take on this kind of job BUT i admire the LOVE you have for your m/h
it reminds me of our first step into motorhoming back in the 1980's it was a x waterboard van which we slightly converted but still slept in a tent but do you know we had the same fun back then as now in a £60.000 plus 5 year old m/h
You may or may not be aware, but all your (van) wiring colours are standard for Sargent systems fitted 20 years ago or fitted yesterday (They have done a nice job at keeping that consistent even while updating and changing the Power Distribution boxes).this is the last of the images ect that i have for now .
so the fridge saga
At 20 years old So It’s due for a replacement. Mainly because it never worked.
it was a Dometic RM 6270. seems there not making them anymore and stopped some years ago.
The alternitve for a replacement was also not being made.
The suggestions for a replacement from the tech team at dometic was something that was never going to fit as it was too wide.
So looking at the Thetford N4080E fridge as a replacement however the wiring is a lot different As this image.to follow
the Thetford was the right width and hight and a 3 way powered fride.
so out the the old and in with the new. Or so I thought.
the new fridge arrived the very next day after ordering .
so i started to remove the old one. take out the grid / air vents outside to the back of the fridge
undo the gas
and that was as far as i could get at the back.
inside open the door of the fridge just inside on both sides were some plastic cover plugs removed them then removed the screws and started to ease out the fridge /
most of the way out and i could see the mains cable
then looked at the 12 volt connections nothing like i was expecting.
i was expecting to see 5 wires . But no.
See image 1
Looking at the image i did however know that the green and yellow wire was cut off .
inside the cable insulation. outer skin
I also knew the the Orange wires with a white line are the negative wires as there throught the van on other items i have had to see to.
The red with the yellow line cable showed it was connected but not live.
started the engine and the red and yellow wire was live.
So that as one of the wires i was looking for as it was the feed through a relay.
the other two negative wire i could not find the ends to.
So now it was back to a fresh rewire of the fridge.
Image 2
If anyone wants to fit a new fridge in a caravan / motorhome / converted van and you cant find the wires than this as far as i know is the install.
now thw wiring is in it was tested. BUT HAD TO BE FULLY LEVEL seems the newer fridges are a bit fussy.
anyway fitted and working.
but never used as very seldom have we been very level .
But thats all about to be sorted soon with an automatic self level system
View attachment 72079View attachment 72080View attachment 72081View attachment 72082
Strange but very true I have just used the carpet cleaner as well but as a small bungalow it does not take longSend me one as well please, just been carpet cleaning the lounge and me back is well and truly buggered and still got half left to do.
They can be very useful indeed. fitted an aftermarket CC to my 2005 RAV4Fitted a self fit speed limiter / cruise control today on our Fiat Ducato 2003 Moho
Following the wiring instructions it was quite easy to fit apart from the plugs to the break pedal
There was not a lot of room but got sorted in the end .
So far works very well tested the speed limiter. That could save to odd fine or two .
And the cruise control also works well. Just the same as our car.
As an after market fitting it’s a great addition ..
Bought from here.
They provide cruise controls for many other Moho as well as vans .
PRECISION CRUISE CONTROL FIAT DUCATO
The PRECISION CRUISE CONTROL FIAT DUCATO is an Original Equipment quality Cruise Control system. This is a Fiat Ducato Cruise Control System and contains many enhanced features such as multiple memory settings and independent speed limiting.www.ncs-systems.com
Sorry there was a single wire to the Clutch not the brake I have amended my post to reflect this .it was soldered into an existing plugThey can be very useful indeed. fitted an aftermarket CC to my 2005 RAV4
Question for you .... you talked about the brake pedal .... did you connect to (or add) a switch on the clutch pedal?
No the accelerator controls the cruise control level speed and also limits the speedSo braking doesn't shut it down or is it connected elsewhere?
