I will second that DelUsually 8mm ...(check first though)
One of these and some gas paste
8mm COMPRESSION STOP END BLANK OFF BLANKING CAP COPPER GAS PIPE TUBE FITTING | eBay UK
Used to blank off 8mm copper pipework. COPPER COMPRESSION FITTING STOP END BLANKING CAP FOR 8mm COPPER PIPE.www.ebay.co.uk
I like the thought Lee but what planet are you onJust leave it open, perhaps squeeze the end so it's flattish and then if you need to toast anything all you need is a match a pair of thick gloves and eye protection, voilà toated bread with toasted Trotter.![]()
When you get older you sometimes need the live life on the edge.I like the thought Lee but what planet are you on![]()
FFS Lee how old do yo have to beWhen you get older you sometimes need the live life on the edge.![]()
Yes there is Jeff. It’s just before where the cap will goI would have thought it had a manifold to turn off that pipe some where ?
Maybe we can arrange something. Either I’ll come up to you, or see you at Hereford? You’re only in the next county.You could always come & see me when I’m back del got quite a few 8 m fittings & pipe I could always make a proper capped off pipe or in my case I took the tee piece out & replaced with a coupler
