How long does your laptop battery last???
I hadn't noticed but when I turned mine on at 07:15 I had pulled the plug out, I just got a pop up 12% remaining @ 10:45 for a 2016 Dell Latitude E5570 I reckon that's pretty amazing.
Three and a half hours?
My 2018 laptop only charges to 80% by default (this is to extend the battery's life), so it is good for about seven hours on battery. I didn't think that was very good.
No idea, but it’s more than 8 hours as I used to use it on long haul flights a lot before I retired last year.
MacBook Air
It doesn’t.
Plugged into mains every time.
Not used often nowadays..it’s years old.
iPad is the way to go.
About 2 minutes Any advice
If you battery is that bad, don't use it. It's a posible fire risk.
Your laptop may work with no bettery fitted, but if it won't, stop using the laptop until the new battery arrives.
Plenty of good after-market ones on Ebay but check feedback first of the ones that only sell batteries.
Liz got 9nw last year for her dell, 11 years old, just do an ebay search if it's okay otherwise, easy to fit usually too.
Laptops running windows will flatten faster because the programes are always running in the background, reboot to linux, head down now.
Just tried turning mine on and now Mines gone flat is this a record ?
Last used march 2008 as i bought an ipad 😉😀
i am non qeek
Seriously, try installing Zorin. It's free and easy to install alongside Windows.
It's similar enough that you'll have no problems using it. The only possible issue is that programs with the same functions are not all called the same thing as they are on Windows.
