Not too good if they are the only AC outletsFitted new trip in electric distribution board , not sure who designed it but 3x 13 amp sockets coming off one 6 amp breaker there’s no wonder it kept tripping so now have the fan heater on a 10 amp spur which allows the low wattage kettle to be used on the 6 amp
The wiring your photos show is clearly not as it left the factory. I think you need to blame a previous owner not the manufacturer for that.That's perfectly normal for an AutoSleeper. They will run three 13A sockets off a single 1.5mm cable running round the van from a 6A breaker. Then some more 13A sockets on a separate 1.5 cable, and two conductors from each cable badly crimped into a 1.5mm dia pin in the mains distribution box. Sparks and fires ensue, successive owners get fed up with all the faults and sell the van and muggins here buys it.
Now all rewired correctly, stupid too-small plugs and sockets removed and replaced with straight-through wiring and Wago connectors. It all works properly.
As far as cable goes, 1.5mm cable is perfectly fine for internal AC Van outlet wiring. absolutely no reason to go larger if you have sockets via a 6A or 10A breaker.
