I rang them & they need to test it, can't get at it to remove it as it lives against a fence, they said to leave it on charge and take it to Halfords who apparently will test and give a report which they are happy with, but it's on SORN, So I'll leave it til the endo of the month when I need to tax it anywayI'd contact alpha see what they say should be covered under warranty. When we had a dodgy b2b solar controller they sent me out a new one
Put a votmeter on it while charging should be about 14volts, disconnect charger and test again should be over 12 volts at least. Batteries do just fail.
bear in mind that most chargers (and I think the CTEKs are in this category) need a minimum battery voltage to actually start up. You said in the first post that the battery was totally flat? could it have been too flat for the charger to actually do anything?I just went down to the van to see how the VB is doing, 0volts still, I looked at the Ctek charger and I may have had it on the wrong setting, but considering it's supposed to be a "smart" charger it's a bit dumb, anyway I've selected as below so hopefully it'll recover, if not I have the booster jobby so when I set off on the 8th I'll drive straight to Alpha and let them check it and go from there.
I would agree David but after 2? days it lit the dash and tried to turn it over.
I don't have one to try that I'm afraidA way to get round this is put another battery in parallel to the charger sees a voltage and kicks off the charging.
Can you suggest one for me to look at David
Sounds like charger gave it a go but battery not interested?I would agree David but after 2? days it lit the dash and tried to turn it over.
Just a possible optionI don't have one to try that I'm afraid
For Victron Kit, the IP67 is a good rival to the CTEK MX range. Very similar devices in style and price point. two differences .... warranty of 5 years vs 3 (or 2?) years for CTEK; and Victron will start recharge from 0V, which can be a handy thing sometimes.Can you suggest one for me to look at David
no. defo not. the current draw is too high. (you can get Lithium starter batteries, but that is a different thing and for a motorhome van, wouldn't bother)I have been meaning to ask, would Lipo make a good or bad starter battery?
I can't remember what your scooter battery voltage is, but there is a 6V/12V switchable charger if that is of any use? current is rather low so wouldn't bother unless you really needed a 6V option as well?Thanks David, I may give the Victron https://amzn.to/42jGs0g a further look at.
Given the 24V scooter battery, might https://www.ringautomotive.com/en/product/RSC808 be an option?I can't remember what your scooter battery voltage is, but there is a 6V/12V switchable charger if that is of any use? current is rather low so wouldn't bother unless you really needed a 6V option as well?
