As David said, AI is only as good as the source information, it cant sort out wheat from chaff.
I'm sure a lot of misunderstanding stems from people not understanding the difference between Series and Parallel.
You definitely should not connect dissimilar batteries in series, of course this info get's passed around and twisted and before you know it the advice is don't connect dissimilar batteries together AT ALL.
Also dealers and garages aren't going to recommend adding a new battery in parallel with a partially used one because :-
A, they'd be putting their head on the line when something else in the van breaks (Like the TV stops working etc) and the owner immediately thinks "everything was OK until that battery was added" the owners then go to a different dealer and of course the 2nd dealer confirms that the first dealt was a "complete idiot and should never have fitted a new battery onto the existing old one because all sorts of terrible things can happen".
B Much easier and far less risk of A above if they simply say, "we recommend fitting 2 new batteries.
C, They get to sell you 2 new batteries.
I saw one AI article that said that paralleling batteries could lead to overcharging and this could lead to explosions!! What a load of Bull. In order to overcharge a battery you'll need at least 14.6V but probably more like14.8V or more, where on earth is this sort of voltage coming from just by connecting 2 batteries in parallel? It's a joke, and so the myth persists.
I did a quick search on you tube for videos of anyone who's actually tested what really happens (in the real world) when batteries of unequal capacity are connected in parallel and fortunately there's quite a lot of tests. I've linked the first 3 I found below but there's quite a lot, thankfully the recent trend for you tubers to monetise videos with science based information along with Lifepo4 batteries with BMSs that allow monitoring voltage and current and the advent of DC clamp meters shows exactly what DOES happen. Unfortunately the monetisation aspect does lead to videos that are needlessly lengthy but you can always skip the waffle and jump to the end for the summary and results. All are Lifepo4 but the laws of physics don't change for lead acid.
