merl
BBC headlines.
Couple die of hunger in their motorhome after they miss lay their fridge door magnet.
Wife's dying words were "Not my fault, He had it last"
BBC headlines.
I really like the neatness of this one, if your fridge door was flush across the front with the cupboard/drawer fronts, it could work that way, then silly bollocks wouldn't get locked out
Never thought of that, but living where I live its probably more of a hassle to get collected than its worth.Not forgetting the outgoing 3 way has a fair value to it.
you'd be surprised. I would not be surprised if I live in a more rural area than you, but I sold my old 3-way for the same I paid for the new 240V Compressor Fridge - and it was collected as wellNever thought of that, but living where I live its probably more of a hassle to get collected than its worth.
The metal trim hides the drill holes in the cupboard faces; when the door broke, we were in a tiny village in the hills, and the 19th century hardware shop had some plant hooks and eyes [for holding up climbing plants etc], so I bought 3 packs of each and drilled the fridge cupboard faces at about 10cm intervals, and used plant string and twine to produce a lace network to hold the fridge door shut. We were then able to travel back down to Vilafranca del Pinedes and lay siege to the Ironmongers, buying brackets, aluminium profiles and threaded rods, plus R clips etc until we got the fridge bracket in the photo. I spent over 100€ but have a healthy stock of the decorative black knobs, nuts, washers and spare aluminium profile which has provided a shed step over the wooden cross beam, plus various brackets and similar for garden tools etc, at prices much cheaper than in UK, so all was not lost; it just felt like it at the time ...Crickey Steve, that looks high security mate....can you put a padlock on it to keep your cold Jaffa cakes safe?
Check you have 12v with the engine running at the fridge. The power comes from no 2 on the master block on some and they fail. Check continuity of the element with an ohm meter. The elements are replaceable.2007 Thetford fridge -
It works really well on gas and when hooked up to 240v but the 12V doesnt really seem to do much.
I'm guessing the 12V is just to try and keep fridge chilled during transit but is it really effective or am expecting to much?
Cheers Alistair.
Definitely got 12V when running as it switches to 12V on control panel, its just the fridge itself doesnt stay as cool as Gas or 240v and thaws out during transit.Check you have 12v with the engine running at the fridge. The power comes from no 2 on the master block on some and they fail. Check continuity of the element with an ohm meter. The elements are replaceable.
Tidy job, it looks about same size as my Thetford.The only reason that 3 way fridges have stayed in use for so long is to cope with longer periods off-grid without driving. Lead acid batteries tend to use up the power relatively quickly. For anyone with lithium batteries the change to a compressor fridge is a logical decision. I have just bought and fitted an Alpicool. Cost just £216 and reduces my electrical consumption from 15A to 8A and runs for about half the time so using about a quarter of the electricity. It is 12v but comes with a 240v power supply so it can run off an EHU supply. Using 2 relays in a control box allows it to choose the source of power (engine, EHU, battery) automatically. I used the original ignitor access to mount the control box and set wiring. In my case all 3 sources of power were accessible at this position minimising cable routing. I added indicator lights next to the fridge to show the source being used.
No more cleaning the gas ignitor when not if it fails. Many 3 way fridges don't use the temperature selector to moderate temperature when powered by the engine so pointless messing with the temperature each time you drive.
View attachment 76641View attachment 76642View attachment 76643
It's for "maintaining" only during travel.....take it down on mains or gas and it'll maintain low temperature whilst you're travelling2007 Thetford fridge -
Cheers Alistair.
As he has said, it isn't maintaining, hence 55 posts.It's for "maintaining" only during travel.....take it down on mains or gas and it'll maintain low temperature whilst you're travelling
Can you tell me the model number of that Alpicool fridge please?The only reason that 3 way fridges have stayed in use for so long is to cope with longer periods off-grid without driving. Lead acid batteries tend to use up the power relatively quickly. For anyone with lithium batteries the change to a compressor fridge is a logical decision. I have just bought and fitted an Alpicool. Cost just £216 and reduces my electrical consumption from 15A to 8A and runs for about half the time so using about a quarter of the electricity. It is 12v but comes with a 240v power supply so it can run off an EHU supply. Using 2 relays in a control box allows it to choose the source of power (engine, EHU, battery) automatically. I used the original ignitor access to mount the control box and set wiring. In my case all 3 sources of power were accessible at this position minimising cable routing. I added indicator lights next to the fridge to show the source being used.
Do you know what they cost new?Never thought of that, but living where I live its probably more of a hassle to get collected than its worth.
In my experience, the thermal print of modern labelmakers looks great when it is new, but in five years the writing fades into invisibility.The only reason that 3 way fridges have stayed in use for so long is to cope with longer periods off-grid without driving. Lead acid batteries tend to use up the power relatively quickly. For anyone with lithium batteries the change to a compressor fridge is a logical decision. I have just bought and fitted an Alpicool. Cost just £216 and reduces my electrical consumption from 15A to 8A and runs for about half the time so using about a quarter of the electricity. It is 12v but comes with a 240v power supply so it can run off an EHU supply. Using 2 relays in a control box allows it to choose the source of power (engine, EHU, battery) automatically. I used the original ignitor access to mount the control box and set wiring. In my case all 3 sources of power were accessible at this position minimising cable routing. I added indicator lights next to the fridge to show the source being used.
