Thanks very much merl and Geek. Gosh all that above is high tech. I still have a NASA monitor that uses a ground
shunt but I don't really trust it so have just used my trusty old Fluke meter from my old life with Machine Tools for volts !
Anyway I'm getting quite apprehensive after all about removing the second Ford
Battery in the Transit and getting into their SCR. It seems describing the second
battery as an 'auxilliary' is missguiding.
Reading on the Transit Forum the second
battery is really the Main
Battery, the whole Body
Battery, and the other is simply the starter motor
battery. They are joined in parallel when the ignition is on and then they are both used for starting too ! The first is the starter
battery and the second does everything else !
On the Transit Forum someone said;
Altransit wrote:
Unless you have changed the standard wiring, BOTH batteries are used for starting, and are also charged in parallel. They are only disconnected from each other when the ignition is switched off.
I'm no expert, but from what I've read on the subject, Lithium batteries are not suitable as substitutions for the standard batteries, and are unsuitable for charging from the standard charging setup.
Because of their use in a parallel circuit, they should both be similar in type, size and capacity."
I understand what you said Geek and how would the Transit know ? but I'm still a bit worried now about removing
battery 2 and putting in the Lithium and the B to B into the Ford SCR. I sure wouldn't like to take out the Ford SCR just with my limited understanding of the drawings I obtained. Of course I can't find anyone at Ford that can help and I realise how difficult it is for you kind folk to advise.
I wonder if I just bought a B to B, disconnected the third
battery and connected the B to B input to the + post of
battery one (as you mentioned merl), and the output to the + post of the
battery three now sitting alone. Then just discharging that
battery and start up and seeing what happens. Maybe all three would be charging as it does now and the Ford factory won't get upset and everything will work OK. ? Then I could replace the third
battery with a Lithium if my choice if it worked.
I know it's a bit inconvenient as you say Geek, having everything under the seats and very cramped but getting cable routes outside the seat positions is awful and I'm not keen on routing down underneath the floor outside then the back up inside to another venue. I reckon to get all I need inside both of the seats bases even if I may need to mount the B to B and
solar control on the outside of the seat base box/es. I see the
Victron stuff needs to be upright, I guess to let the heatsinks work.
There again I'm back to thinking about what you said Geek......."not removing the SCR is what leads to a disaster"
Maybe I should forget it and leave you all in peace.
