Thanks again Geek you are very patient indeed.
I have always been and still am confused with the intention of the Ford set up considering it's an 'option'. The second
battery is sometimes referred to, by them, as ; Main
Battery, Aux
Battery, Deep Cycle
Battery or Non Start Relevant
Battery. What I see as the only SCR in the vehicle is sometimes called ;
Battery Disconnect Switch or Charge relay or Split Charge Relay. This switch has 6 terminals ; the two 190A
battery heavy duty contacts, then 2 coil connections, then a pull in and a pull out.
This item, I'll refer to as 'SCR' is well and truly integrated into several more functions than, what I normally would have expected of an SCR to be involved in. It is also very well buried, into the most inaccessible region of the very full, drivers seat base. If I can only achieve my aim by getting to this SCR and working into the wiring of it, as seems to be the case, I think I'll likely give up on my plans to be honest. Apart from having to completely strip out the whole seat base I would be concerned about messing up the functions of all the other things reliant upon it, not simply just disconnecting the
battery + posts when the ignition is off/engine stopped. Even
Battery logic on and off is in there amongst it heated screens etc !
I'm going to try to include 4 photos of all the Ford Drawings I have and a picture of the two front seat bases so you may be able to see what I mean. I have marked in rough pencil on one of them where I connected the third
battery and where Autosleepers connected their habitation equipment wiring directly to the second
battery rather than using the fused customer connection terminals provided by Ford. The photo shows the drivers seat base with the starter
battery and the 'second'
battery basically as factory built, and in the passenger seat base the third
battery I added in Parallel and the Morningstar
Solar controller I put in years ago.
As I've said the whole thing has worked flawlessly (the second and third batteries replaced on a couple of occasions, now due) for almost 19 years I think. The only trouble I've found is the power available when sunlight is short is a bit skinny, plus a much shorter
battery life than Lithium. I'd really like to have all the benefits of Lithium but it just seems too difficult though the costs of the
battery and a B to B and maybe a new MPPT don't concern me. It's just that having to poke around in all that mysterious Ford stuff with the canbus watching me that I think is beyond my abilities now at a creaky old 78 !
There again as you said I could replace the second
battery with a bigger one (Lithium) and a B to B, would I just have to get to the two
battery connections of the Ford SCR and insert the B to B between them ? But surely the Ford stuff would be upset to find a Lithium
battery where it previously had an EFB lead acid type, or something else to upset it, would it ?
I still think a 150AH Lithium (so back to two batteries total instead of three again in this case) would be sufficient for me with the much more usable capacity of the Lithium Technology.
Maybe I should just tough up and get on with it.
Very many thanks for all your time and patience.
Pete
