Millie Master
The problem is Nigel, the length of the screw and what type of roof, it is glass fibre then the screws are no good and if there is next to no insulation before the trim the length of the screw is so vitally important as I wrote in my earlier response.i used stixall ,using matches to give a 2mm thickness ,then added one of these to each bracket ,tightened a bit them smeared the heads with more mastic https://www.screwfix.com/p/easydriv...PYnp21CST36OOKTswuMaAnC5EALw_wcB&gclsrc=aw.ds
