Replacement batteries advice please
Vanterrier
We have a 2008 Boxer Autosleeper Symbol van and use it year round on EHU and non-EHU sites equally.
Our normal power usage is:
TV and Diesel heater in colder/darker months
Two showers each morning - Shurflo pump
3 way fridge
LED lights throughout
No inverter, or other hi load 12v items.
Have a Victron smart charger and B2B charger between LB and VB
Existing Yuasa 5019 YBX batteries are of unknown history prior to me buying van last June and without victron charger drop to 12.4 VB and 12.1 LB in a couple of weeks so I want to change them but what to?
I think I will replace the VB with another Yuasa 5019 YBX
But I really want an AGM or EFB LB for those off grid nights
What do you recommend?
I'm currently looking at:
Yuasa L36 AGM 95Ah at £180
Yuasa L36 EFB 100Ah at £130
Leoch Adventurer AGM 130 Ah at £185
Leoch Adventurer AGM 160 Ah at £295 !!!
Leoch LAGM 110LL. 120Ah at £168
But there are others like Exide and Numax...
Is there any issue connecting a 160 Ah LB to a 100 Ah VB via the B2B?
Advice please, much appreciated
K 😉
If you can fit a 160AH Battery (have you checked the height requirement?), then I wouldgo for the Expedition Lead Carbon battery - https://www.alpha-batteries.co.uk/1...rbon-gel-ultra-deep-cycle-battery-exp12-160c/ - for £245.
There is a 110AH version for £190 which is pretty much the same footprint but a lower height than the 160AH version - https://www.alpha-batteries.co.uk/1...ad-carbon-ultra-deep-cycle-battery-dc12-100c/ (this is a gel battery like the160Ah. ignore that the link says 'agm')
The Lead Carbon type of Lead Acid Batteries are the best type and longest lasting option.
I've had a pair of those 110ah lead carbons for a couple of years now, they have been excellent. I don't know of any other lead acid battery that comes anywhere near the 1500 cycles quoted
They are excellent batteries. I've had 3 of those batteries in my own motorhome for close to 6 years now and while they are act as a 'secondary' battery in my Hybrid setup, they still provide full capacity when called on as far as I can tell (based on voltage vs capacity tables).
Victron sold a previous lead acid battery that was dubbed the 'immortal' battery as it work so well and then later replaced with the superior Lead Carbon technology. I tried to use ChatGPT to provide a description of this as thought it would be useful, but its reply actually just quoted a post on Motorhome from 2021 posted by myself :) So guess I just have to believe myself :D
Another vote for lead carbon had mine for 4 years .only down side is rhe weight ,
The first ones I got were from Phil/Admin when he was changing to Lithium for the first time in his Hymer.
Excellent 210 Ah batteries and got three of them but each was a hefty 71Kg! Couldn't lift them up as so heavy.
Of the type I linked to, I've installed the 110AH, the 160AH and the 200AH versions and everyone has always been very happy with them.
These days it's a no brainer to fit LFP leisure batteries , twice the capacity per ah and if isolated little to no self discharge.
They are as cheap or cheaper than some of those you have mentioned and the lifespan is 5 to 10 times that of lead chemistry batteries.
Your Victron charger and B2B will have a LiFpO4. Profile already so all you need do is change the default in settings.
Dave
