UFO
Our Adria Twin is nine years old and I think there may be some water ingress. Whether there is or not it seems like a good idea to replace the sealant on the Seitz Midi Heki Rooflight Vents and the toilet roof vent.
The current sealant is very soft and black but if the surface is broken it is white underneath so probably black from all the stuff in the environment.
The rooflight vent appears to be in two pieces each with its own sealant layer, probably because the vent fits on a flat roof and the extra piece is needed to fit the ridged roof of the panel van.
I’d prefer not to remove the vents, unless it is necessary to get a good to seal. My plan is to remove all the existing sealant that is visible, thoroughly clean all surfaces and then cover with new sealant.
Any advice from anyone who has done this job before would be appreciated, including which sealant to use.
