Rec
Have you tried laundry balls? We use them in our twin tub offgrid in portugal, Need less rinsing...just one with lavender oil dropped in for perfume. Used them for years and fine if clothes are not very dirt. Then you need to use a stain remover first and extra rinse after wash.We have a portable twin tub. I’ve had it for two years now and would not be without it. We mostly wild camp and prefer to. The twin tub means we don’t have to go to campsites as often as we used to. The only thing we need is access to water as it uses quite a bit to rinse. If it is sunny we can run it easily off the leisure battery and the sinewave inverter. In the past, we have resorted to running the engine just to keep the batteries charged.
A good tip is to use soap nuts, bicarb soda and white vinegar. Cleans well, no smell and uses much less water in the rinsing as less soapy suds.
Reckon it has more than paid for itself, probably 10 times over. We have come across campsites that charge as much as €10 for a wash.
And on a sunny day with a glass of vino it really isn’t a chore.
