Deleted member 4850
Can I join a further 100w solar panel in conjunction with the 80w fitted to our Autosleeper into the 80w connection.
Maybe a stupid question but!!!
I have huge amount of mechanical experience, not so electrical, So understanding the issue fully, allows me proceed. To wire for the leisure batteries no problem, Autosleepers system charges engine and leisure, looking at MPPT controllers,correct me if Im wrong would it not be foolish to have a 100% charge going into the engine battery from a alternative supply ie new controller. I understand the leisure is a drain and charge situation but not so a engine battery when static.By the sounds of it you will need a new controller, go for MPPT type as this is better than PWM and similar price for a decent one, and connect both panels in parallel either on the roof or inside the van then into the controller, you may need to buy a connector block to make your life easier.
For safety always pull fuses, and site the controller as near to the batteries as possible, connect the batteries to the controller first and then the panel, and if you have to disconnect the old panel, disconnect the panel first.
there are lots of youtube videos if like me you prefer the monkey see monkey do approach.
If you're just changing one controller for another, it shouldn't make any difference to however your engine battery gets charged... I don't think. As I said before, my knowledge is basic but I'm pretty sure it's normally a separate gizmo to control and divert solar power to the engine battery, not the solar controller itself. My first 130W solar had an old pmw controller to deal with the power coming down from the roof and a separate "battery master" that diverted a bit of power to the engine battery when needed. My new system has a 245W solar panel and a lovely MPPT controller that can cope with up to 440W of solar power if I ever wanted to add another panel. Again, there's a separate gizmo to serve the engine battery - this time a Victron Cyrix battery combiner that lives under the bonnet.I have huge amount of mechanical experience, not so electrical, So understanding the issue fully, allows me proceed. To wire for the leisure batteries no problem, Autosleepers system charges engine and leisure, looking at MPPT controllers,correct me if Im wrong would it not be foolish to have a 100% charge going into the engine battery from a alternative supply ie new controller. I understand the leisure is a drain and charge situation but not so a engine battery when static.
Definitely NoI've never used the load terminal, but would that be useful to send to the starter battery?
In short, if your Autosleeper system already has a separate gizmo to serve the engine battery, then wiring it in to a replacement solar controller shouldn't make any difference to its continued function...
... I could be wrong but it seems logical to me!C'mon all you experts... let's have a simple explanation.
80 w was the factory fit on autosleeper , replacing the earlier 30 wcan you see underneath the existing panel - maybe with a mirror - and see any label info? or would Autosleeper be aable to provide the specs of the panel - you want to know the Current and Voltage numbers (not all 80W panels are created equal)
Depending on the specs of the panels, you may need to connect them in parallel OR in Series to get maximum results. If you can get the specs of the original, you can find the most suitable panel to add.
it is not the fact it is 80W. it is the voltage and current specs which are the key.80 w was the factory fit on autosleeper , replacing the earlier 30 w
I'm a fan of the Votronic MPPT controllers withe separate trickle charge for starter battery.One of my controllers is a Votronic Duo. These put the majority of the harvested power to the habitation bank but also send a 1amp trickle charge to the starter battery. Most if not all things in the habitation area should be running from the leisure battery bank so that’s where you need most power to go, you should only have a small drain on the starter battery if any at all.
Never checked what mine puts out, I ‘thought’ I had read it was 1 amp in the manual but will have a check thank youI'm a fan of the Votronic MPPT controllers withe separate trickle charge for starter battery.
I thought it was 1A max so used a 2A fuse and that's been fine for a few years.
However last week after having had the starter battery out to weld up the suspension turret I noticed that it wasn't charging.
I checked the fuse and it was broken - didn't look blown but it might have done because when I put my multimeter in line instead of a fuse it was charging at 1.5A rather than 1A 'max'
I put in a 5A fuse and now the battery has stabilised the trickle charge is about 0.4A.
How close do the specs have to be? Does it have to be an exact match? Is it the open circuit voltage we need to look at?it is not the fact it is 80W. it is the voltage and current specs which are the key.
