andrew65b
No it doesn't Trek.  Not sure if that was an option, or a later model thing.  Mine is a 2012.
			 www.melloronline.co.uk
				We plan to use for skiing too, and hence why I too am interested in using to pre heat alsoRegarding heater performance during winter
Modern diesel engines do not have an excessively amount of waste heat but Teeing into the heater circuit wont make that much difference on a long run especially if the heat extracted via your modifications are used to heat the rear of the van
Instead of just a hot cab and cold back end the whole van should be at a nice temperature
Saying that luxury cars and some sprinters have these webasto or eberspacher auxiliary diesel heaters to boost the coolant temperature to the cab heater matrix ( and in my case the heat exchanger as well) so if its extremely cold then this can be switched on ( when i travel to the ski resorts its not often I use this booster apart from pre warming the engine prior to starting it )
				 alde.co.uk
					alde.co.uk
				but surely I need to have an electric pump on the habitation side of the heat exchanger?You don’t need an electric pump if you want to take advantage of waste engine heat whilst driving as the engine water pump will circulate the hot coolant with the engine running
Electric pump would be required to heat in reverse the engine via the heat exchanger and some heat source in camper whilst engine off ( i.e. pre warm engine before starting - very good thing to do in winter in ski resort which is what got me started with these diesel heaters as years ago my then IVECO camper stuggled to start in VERY cold conditions )
Or to use the residual heat in the engine block after turning off the engine ( i.e. Mercedes REST function )
Fiat Ducato so mostly the same as yours, the examples of fittings I saw were on Peugeots, Citroens and Fiats, all done the same way.Thanks Familywagen. What sort of van do you have?
Thanks Familywagen. I'm having trouble sourcing unequal Ts to T into the cab heater pipes and provide 16mm to the heat exchanger. Can I ask where you got yours please?
