Agree with that Gordon.They hold 10-20 litres every second fuel up fill up ad blue whether needed or not or you can crystallise the dpf ( ad blue system)
This can cost a lot of running issues as well as expensive repairs!!!!!!!
I didn't know that! How does topping up stop the pdf becoming crystallised ? I'm not doubting what you are saying but would like to understand how. I only get 1500mls or so each fill.They hold 10-20 litres every second fuel up fill up ad blue whether needed or not or you can crystallise the dpf ( ad blue system)
This can cause a lot of running issues as well as expensive repairs!!!!!!!
Adblu contains uric acid ....and it forms crystals for fun (look at any adblue spillage )I didn't know that! How does topping up stop the pdf becoming crystallised ? I'm not doubting what you are saying but would like to understand how. I only get 1500mls or so each fill.
White wine and ale does not sound like a good mix!Adblu contains uric acid ....and it forms crystals for fun (look at any adblue spillage )
General thought is crystalline deposits block the Adblu breather cap and then cause the Adblu pump to strain and eventually fail OR cause issues with delivery amounts .
Regular top ups help to keep the adblue from settling in the tank (despite driving agitating the tank slightly )
BUT more so from regular venting of the tank too .
For the cost and amount of adblue ...just brim the tank .
My work van drinks it like I drink white wine and real ale ....
It's surprising WHAT you can mix when you practice lolWhite wine and ale does not sound like a good mix!
I didn't realise they hold that amount. With everyone saying not to put too much in due to light use to stop crystallisation, I thought just a couple of litres would be find. Maybe that is why the light is still on after having driven around 70 miles. I shall put the other 3 litres in that I bought. First time with ad blue so learning curve.They hold 10-20 litres every second fuel up fill up ad blue whether needed or not or you can crystallise the dpf ( ad blue system)
Everyone on here says don't put too much in or it crystallises. From what someone else has now said, I shall put the 5 litre can in.Don't be so tight for heavens sake, put a full bottle in!
One of the most painful conditions I've ever suffered with to be honest ....And wine has a contributing factor (although small) in the disease gout which is caused by uric acid crystallising in the joints. It particularly affects the feet causing the sufferer great pain and an inability to walk.
So really allowing ad blue to crystalise in the tank is like giving your vehicle gout!
Davy
Who can disagreeIf your fuel light comes on you would fill up with fuel if your ad blue light comes on fill up with adblue easy. I really feel like I’m in the wrong planet sometimes. Trev you got a spare room on planet TREV.
It'll start screaming at you that restart is only possible for so many miles on most vehicles .Yes but how urgent?
Fuel light gives 100Km
