marchie
Have you looked in your Manual? Do you have an Adblu gauge or Menu Item that will give an approximation? Do you drive with your right foot pushing through the cab floor? Are you always pushing your payload limit to the max, and then climbing the Pyrenees? All of these factors can make a huge difference to Adblu usage, and hence the safety margin before the vehicle cannot be started. If you know the odometer reading when the Warning Light first appeared, make a note of it and also record the amount of Adblu to refill the Tank. Assuming your driving style/trips are similar, you should have quite an accurate consumption figure to act as a guide for next fill up timeYes but how urgent?
Fuel light gives 100Km
