So this is the gauge set
(the hole in the middle is where the switch will go. Easier to wire it up and then push it in place).
Need room at the back for 4 thin air hoses to come out, which will have minimal bending available to avoid kinking.
Looked at the little cubby in the dash which would be the most handy. But it will also be the longest run of pipework for the airbags and compressor and the most awkward to install I suspect.
Looked at an area behind the drivers seat. That could be ok, but it would't be the easiest to get to I think either to make adjustments.
Offered up the gauge set at a few other places ... thing is it is not the most attractive of mounts and is hardly something you really would want that visible. At the dash is probably best IF you have it 'on show' but how often would you make adjustments which means you want to within reach of the driver?
And bearing in mind these comments ...
I am thinking one place I looked at might be the winner, winner, chicken dinner?
Under the sink!
Access door to sink closed
Door dropped down
So not on show; easily accessible to make adjustments, taking up space that is otherwise wasted (I think!?) - so maybe even more handy than in locker?, and pipework easily routed and just about as short as possible as this is right above the rear wheels.
Seems this is the place to use
Mine are in the garage, (no compressor) I don't really adjust them other than topping up one that must have a very small leak......
where the gauges are not even in the cab/living area at all, confirms to me that it is something you setup and then tend to leave alone (unless you have a leaki only have bellows on the rear suspension the twin gauges fit in a convenient recess just inside a rear locker ....
Under the sink!
Door dropped down
