Exwindsurfer
Engines where a lot easy to work them days .
My first vehicle was a Bedford 8 cwt Van that had a starting handle; for good reason ...Engines where a lot easy to work them days .
While some components/functions are the same most new stuff is no longer something for DIY folks to do. You need to be much more of an enthusiast and get hold of specialist kit (and learn how to use it) these days. That’s all doable though but for me there just isn’t access any more. Open the bonnet on a lot of new cars and you don’t even see the engine. So many sensors as well these days. We used to have a laugh at the amount of folks who used to change crank/cam sensors because simple diagnostics showed a fault, it always would as it registered with engine stopped not running (Vauxhall Vectra).Engines are not that different from back then, still Suck Squeeze Bang Blow, just more crap attached to them.
I think that's only true to a degree, Kev. The original style of engine was totally reliant on physical parts, so it was possible/necessary to whip out the failed compnent [or strip down its innards and replace the broken spring/leaking seal etc], slap a new part in, and go. Modern engines have sensors galore, electronics that emulate the performance of a petrol engine with the economy of a diesel, and a software package that makes most maintenance a specialist function, and replacement of components a very expensive set of pcbs, sensors et seq. Feeler gauges [or foil from a fag packet in an emergency, and home made static timing lights, and tappet adjustments are museum processesEngines are not that different from back then, still Suck Squeeze Bang Blow, just more crap attached to them.
I remember when I got my first Saab back in around 1980, mate was a mechanic at the dealers and said it was fine to do anything I wanted but DO NOT touch the Bosch fuel injection kit. Seems they were somewhat specialist setup lol.I think that's only true to a degree, Kev. The original style of engine was totally reliant on physical parts, so it was possible/necessary to whip out the failed compnent [or strip down its innards and replace the broken spring/leaking seal etc], slap a new part in, and go. Modern engines have sensors galore, electronics that emulate the performance of a petrol engine with the economy of a diesel, and a software package that makes most maintenance a specialist function, and replacement of components a very expensive set of pcbs, sensors et seq. Feeler gauges [or foil from a fag packet in an emergency, and home made static timing lights, and tappet adjustments are museum processes
I remember reading in a Car Magazine about the water injection for cooling; IIRC, it was just a drop at a time and it was transferred from the Washer Bottle [or an extension thereof; don't remember if screenwash was going to be problematical, just recall thinking what an ingenious idea it was!]I remember when I got my first Saab back in around 1980, mate was a mechanic at the dealers and said it was fine to do anything I wanted but DO NOT touch the Bosch fuel injection kit. Seems they were somewhat specialist setup lol.
Point of interest maybe, was that garage that developed water injection that Saab picked up and actually fitted to their cars, was then Rock Bay garage at Burbage just outside Buxton.
Not the same as Saab did Steve. They injected a fine mist into the inlet manifold to give a power increase, quite significant as well but you ran the risk of wrecking the engine if water ran out.I remember reading in a Car Magazine about the water injection for cooling; IIRC, it was just a drop at a time and it was transferred from the Washer Bottle [or an extension thereof; don't remember if screenwash was going to be problematical, just recall thinking what an ingenious idea it was!]
as a sign of things to come when Honda started fitting nicosil (sp?) barrels on I think it was their NSR. Who on earth thought it was good to not be able to retire a barrel? Think that was the start of the throw away era for me, not that I had an NSR although Caz did insist I bought her an Italian import NSR 125 RRR (not sure how many r’s but there seemed a lot). Personally I would rather eat worms than ride a HondaI didn't say they were not different, I said "Engines are not that different from back then" Of course they are different, a lot lighter due to more aluminium, more efficient due to smaller tolerances, belts instead of chains mostly, better valve technology, more valves in some cases, but most of the changes are outside
My IIRC was obviously not correct, Neil! As soon as I saw 'fine mist', it rang a bell! My excuse is that it was around 30 years ago that I read the article, and 2 of my 3 brain cells have dies since ...Not the same as Saab did Steve. They injected a fine mist into the inlet manifold to give a power increase, quite significant as well but you ran the risk of wrecking the engine if water ran out.
Anyone who had a two stroke motorcycle back in the day can appreciate how much more power you got on a foggy day![]()
A third class ride is still better than a first class walk thoughW
as a sign of things to come when Honda started fitting nicosil (sp?) barrels on I think it was their NSR. Who on earth thought it was good to not be able to retire a barrel? Think that was the start of the throw away era for me, not that I had an NSR although Caz did insist I bought her an Italian import NSR 125 RRR (not sure how many r’s but there seemed a lot). Personally I would rather eat worms than ride a Honda![]()
Typo ?A third class ride is still better than a first class walk though
No, tis wot I rote.Typo ?
+1I had brake warning light come on my Sprinter must be getting on 4 years ago. Contacted local garage I used before I left Peak District and booked it in. They got everything that may have been needed to change the lot front and back (sale or return with factors). When it came to the work they changed front disks and pads and rear pads for a grand total of I think £92 including parts, layout and VAT.
Highly recommend Stella Motors in Dove Holes if anyone is in the Buxton area and needs work doing. They used to charge me £28 for MOT as well![]()
4 strokes as well Neil, I could always notice a difference on my old Super Rocket on a damp day.Not the same as Saab did Steve. They injected a fine mist into the inlet manifold to give a power increase, quite significant as well but you ran the risk of wrecking the engine if water ran out.
