Phantom
Our Camos satellite dome used to work fine though we hardly ever use it.
The last few times we tried it went through the usual motions and fine tuning but failed to lock on to Astra 1. The satellite select button does not change it from Astra 1 though maybe that is the only satellite available, or is something wrong? After a while the 'lock on' briefly illuminates and it appears to scan for available satellites then settles back on Astra 1 but with gets no lock, this same process repeats every so often.
I plan to measure the signal strength then remove the dome cover and check connections etc. I heard that aging dome covers can weaken the signal, so will test without it on.
Any thoughts?
Any thoughts?
