There are several weight ratings that matter. They are
GTW - the maximum weight of the vehicle and its loaded trailer.
GVW - the maximum weight of the vehicle including everything: load, fuel, passengers, dirt. Everything.
Weight limits for each axle. Normally the individual axle weights add up to more than the GVW.
MIRO - the mass in running order. That's the weight of the vehicle, plus some fuel and a driver. Basically what it weighs when you drive it out of the dealer's showroom.
UW - Unladen weight - This is impossible to measure once the vehicle has been built, because it includes the weight of the items that are "used on the road" but not the items that are not used on the road. No water, no gas, no water tank, no gas tank, no mattresses, no beds... basically the bare shell of the motorhome. Some people dispute this interpretation, but the law says what is says.
Some makers publish a UW figure, but not many. As far as I know only the UK uses it (to define the speed limit of the vehicle) so many makers quote a MIRO figure as the UW - which is just plain wrong.
Normally you can go to SV Tech or JR Consultancy (cheaper) to get your GVW increased, but it is rare to be able to increase the official axle weights, so using the extra capacity may require very careful loading.
