Foot right off the gas going down hill until the speed drops too far, then gently gas it again, see a red light off the gas, see a queue off the gas, read the road, try not to brake or worse still stop.
hi pudsy bear . how comeThe 56mph is a hell of a myth, economy comes from how a vehicle is driven and it's shape, a Luton van may run at a totally different economical speed to a Fiesta car.
hi guys . yes your right hgv's speed limit is 60mph BUT are governed at 56mph . had many a restrictor go belly up so took advantage & drive up to 60mph . i was in pulled in the layby enroute to barrow for checks not over weight but looked at the tachograph & said get the restrictor sorted but never got charged for speeding even though the police was there . they brought out the taco's in the UK in the early eighties .cheyenneIt was part of the European triumvirate of speed standards for years, Kev. Manufacturers were required to state fuel consumption at a constant 90kmh, at 120kmh,, and, IIRC, an urban cycle of 50kmh. The measurements have been changed over the years and now take into account hybrids and electric vehicles and the odd diesel emissions scam (VW were very wrong in their actions...)
hi simon. yes they have but its not all departments have gone back to the old limits .cheyenneA little while ago France decided to reduce their 90kph limits down to 80kph (56 to 50mph) in order to reduce pollution, or road deaths, or something Gallic. Then the truckers were all up in arms saying they ran most efficiently at 90, and now many of those 80 limits have been rescinded and are back at 90.
Please read my post #39
The old engine was about the only thing good on a tranny, lots of folk maranise them with intercooler kits for boats, i have a kit and engine here to build.And zero electronics too unless you have a radio in it![]()
great old Trannys, I had a couple of smiley front ones, I keep seeing one of my old ones trundling around Bradford now and then, rusty as hell but still going on.
Liz says we should look at getting and old van but it would have to be a tranny, R reg with turbo at least..
I find the 80km/h speed limit a mite slow and it also makes it difficult to maintain cruise control in 6th gear if one encounters even moderate hills, whereas 90km/h enables one to cope with a greater range of inclines in 6th gear.We are in France and I love the 80kph speed limits. I can tootle along without holding others up. We are currently in Dreux, after visiting Le Mont Saint Michel and Arromanches for D-Day. So far, around 28 mpg. Fully loaded with water, food and whisky! Oh, and my good lady, the bad one couldn't get away this week. Yep, 80k on cruise control, through the beautiful French countryside. I couldn't be happier.
Is that strictly true? Revs are part of the equation but I think the amount of throttle used also has a big bearing on the fumes. i.e. Being in too high a high gear with the right foot hard on the floor will use more fuel and create more fumes than dropping a gear.lower gears = higher revs which = more fumes.
My VW Up is exactly the same.Same on our Fiesta, 30mph = 3rd gear, need to be over 40mph for 4th
Not entirely sure but it seems reasonable that if your engine is spinning faster it will use more fuel and create more exhaust, but bearing in mind what you say, it might burn cleaner so could be less polluting.Is that strictly true? Revs are part of the equation but I think the amount of throttle used also has a big bearing on the fumes. i.e. Being in too high a high gear with the right foot hard on the floor will use more fuel and create more fumes than dropping a gear.
I am not entirely sure either but I do know that the amount of fuel injected depends on how much throttle is used as well as the revs.Not entirely sure but it seems reasonable that if your engine is spinning faster it will use more fuel and create more exhaust, but bearing in mind what you say, it might burn cleaner so could be less polluting.
Dunno.
Yep, the weather is affected by pollution too. They now have to wear masks in the USA because Canada is burning too much wood. Getting old helps we can leave the problem for others to sort out.I'm no lookin forward to getting old if that's the worry you are all getting, what's next the weather?
