Ahh this may have assisted me in a similar issue
I have in another post tried to get the solution Set up - 2x120W
solar panels in parallel, a capable 20A Voltronic Controller into a 95Ah
battery under drivers seat which in turn is linked in parallel to another identical
battery under a side facing seat behind passenger seat
Issue?
Vehicle status board shows (Consistently) Starter 100% (3 green LEDs) Cool but
Leisure batteries (Or is this only showing the
battery status under my seat) at 66% or 2 LEDs
You see when I bought it it only had 1
solar panel & 1 leisure (Under my seat)
So I added both recently but when driving both are 100%
I am now thinking that the way the wires from
solar controller directly to
battery under my seat & from there are connected in parallel to other
battery under side seat could be the issue?
ie should the power wires from controller have a) one terminal on 1st
battery only (Under my seat with say positive)
b) The other power wire be connect to the side facing
battery (with negative)
Here is a crude paint pic of current setup
Any replies greatly appreciated
