Skyfive
Has anyone with an Elddis Autoquest 196 had any problems with the bunk blowing fuses?
If so, how did you resolve it?
Thanks in advance!
Thanks in advance!
Elddis fit STLA rise and fall bed with seat belt hanging system
nice one ladies hope you are both good ,did you get you gas problem solvedHi, are you still having problems. We had a 196 on a 17 plate that kept blowing fuses on the drop down bed. We were told by the dealershup to increase the fuse from 20 amp to 25amp. This solved the problem. Finding the fuse is another problem. It is hidden in a space above the drivers seat on the ledge.
can you please advise where to find the fuses as mine has not works since I left the dealers, which is 200 miles away. I have called dealer who does not know? The reset fuse above driver seat is fine but do not know where to find the other one. If you press the buttons it clicks but no movement.It seems to ok just now it has blown 25amp that’s an in-line fuse that is on a cable from the leisure battery and it has blown the 10 amp auxiliary fuse that powers the switch for up and down .The fuse above the drivers head is the only one it hasn’t blown they have change that fuse to a reset fuse that has a button on top to reset it haven’t seen one before my 196 is a 2020 model I have notified dealer but I’m 128 miles away from them so I will just see if it persists cheers for all the replies
Many thanks I will look in the morning
thanks for the information, I read that fuse label and was not sure what it was for, thanks again for your help
