cgwcmlw
We have a combination of Sargent ec500 and EC480 control panel and we had a similar problem. I contacted Sargent support and initially diagnosed the problem as the Solar panels given out to high a voltage, the solar controller was changed on their instruction but didn't fix the problem. I was then instructed to read the voltage of the Leisure battery, ensuring the battery charger off and solar panels disconnected and comparing this with the voltage displayed on EC480 control panel, the control panel reading should NOT be higher than the leisure battery reading. In my case the control panel was reading higher by about 0.2V higher causing the unit to intermittently trip. This indicated a fault in the Sargant ec500 power supply unit and was replaced, all OK now. I appreciate you have a different Sargent set up and your control panel doesn't display battery voltages, but certainly worth an email to Sargent support the diagnose fault, very helpful and prompt.
