PeteS
Is there not a danger that the more you turn the contol up the more heat is generated and you reach a point where it cannot extract that heat anymore and the end result is the temperature in the fridge rises. Using fans to draw more air thru would eleviate the situation and allow the fridge to cool further.
In my case with a Dometic fridge freezer RM5???I think! I run it at around 3 oclock 11 o'clock being full on so about 1/4 power and in all temperatures it is fine apart from the freezer icing up after a few weeks continous operation. I did run it nearly flat out once when we first got it and realised the burner was on continuously and not really cooling very well.
Even at 3 oclock items in the main compartment freeze if they are touching the fins at the rear, so I wonder if yours is turned up too much and maybe try turning it down and see what happens?
