Yeah, good idea Trev, I'll go and buy those and not bother with the half dozen bottles I already have.Blue stuff, use bio wash tabs.
Just pub banter, im one to talk LOL.Ahhh, I see your point Trev. Poor grammar on my part. Many thanks for your correction.![]()
I remember Mum & Dad buying a caravan with the foot operated water pump that you describe! Would have been an Ace [Viceroy] or a Thomson. And when Dad fitted a Leisure Battery so that we didn't need to worry about Gas Lamp Mantles failing! All condoms [i.e. mod cons for the dyslexic ...]That caravan sounds so much posher than our first one. Ours had an exterior water barrel full of cold water that I pumped into the internal tap by repeatedly pressing on a rubber bulb built into the floor.
To make it hot we boiled a kettle, and we thought it so modern compared against the previous mountain tent and frame tent. Who really needed lithium in those days?![]()
We must have had a deluxe model, as I seem to remember that our gas mantle had levels to turn off the gas. We only turned the gas bottle off when we left the van unattended or when we travelled.
Yes, had one of those as wellThat caravan sounds so much posher than our first one. Ours had an exterior water barrel full of cold water that I pumped into the internal tap by repeatedly pressing on a rubber bulb built into the floor.
I guess "solid" may have been a slight exaggeration as I could take it off the hook and lay the head on the shower tray. The hose didn't change shape as I moved it though!Gently I hope David, stanby with cloths if it's frozen so high up and leave the taps open.
I left the fresh and grey water tanks plus water heater empty after the sterilisation and descaling exercise, and left the grey waste water drain pipe open and the Frost Valve open and all taps open. I think the shower hose is empty [I was paranoid about leaving any corrosive, however dilute, water in the pipes from the descaling, and then showering my important little places weeks later!]. The bathroom and kitchen taps should be empty after I opened them up last week and just got a brief 'phut' of a few drops of water from each tap when I turned them on and ran the pump for 2-3 seconds The toilet cassette is empty [and fed from the fresh water supply], so I *think*/hope I'm ok now that the temperature has risen to minus 4 degrees ...Gently I hope David, stanby with cloths if it's frozen so high up and leave the taps open.
What, in these temperatures? I'd need to organise a Search Party [perhaps Cavers and Potholers, given their expertise]I pump out when I drain down.
Loads of stuff, cushions on edge (just shout at them) wipe down fingerprints (or the rozzers will have you) open blinds, some sun will get in and help, and the springs won't stretch, turn wheels to kerb or a wall just in case, silica bags in wardrobe and fridge/freezer.I left the fresh and grey water tanks plus water heater empty after the sterilisation and descaling exercise, and left the grey waste water drain pipe open and the Frost Valve open and all taps open. I think the shower hose is empty [I was paranoid about leaving any corrosive, however dilute, water in the pipes from the descaling, and then showering my important little places weeks later!]. The bathroom and kitchen taps should be empty after I opened them up last week and just got a brief 'phut' of a few drops of water from each tap when I turned them on and ran the pump for 2-3 seconds The toilet cassette is empty [and fed from the fresh water supply], so I *think*/hope I'm ok now that the temperature has risen to minus 4 degrees ...
M/Home is parked in gear with the handbrake released. Anything else I should do, Kev, [or anyone else!]
Fridge/Freezer propped open and M/Home opened up a couple of times each week. Blinds open, soft furnishings indoors, drop down bed lowered by 2 or 3 ins to allow air to circulate. Cupboards emptied, though repacking underway for early January departure.Loads of stuff, cushions on edge (just shout at them) wipe down fingerprints (or the rozzers will have you) open blinds, some sun will get in and help, and the springs won't stretch, turn wheels to kerb or a wall just in case, silica bags in wardrobe and fridge/freezer.
