Burge
Wish I had known before...never mind c how it does, thanks Chris.This fool has one, and it works 100%
I only have a small camper so no room for a bigger panel or 2 batteries.
There will be a space somewhere, they do not have to be aside each other, mine has one in the front footwell and second one down the back beside the fridge, a heavy-duty battery cable links them up, and what about a folding panel to put up at the windshield when parked facing the sunI only have a small camper so no room for a bigger panel or 2 batteries.
Believe me, there isn’tThere will be a space somewhere, they do not have to be aside each other, mine has one in the front footwell and second one down the back beside the fridge, a heavy-duty battery cable links them up, and what about a folding panel to put up at the windshield when parked facing the sun
Two tyre levers and some vaseline.Believe me, there isn’t![]()
'Won't that hurt?'Two tyre levers and some vaseline.![]()
Carrol Consider energy expedition plus lead carbon , they can be discharged deeper than lead acid and have 1500 charge cycles not the usual 250..only problem is they are a bit heavyer and more expensive . I have one and Jenny M has has 2 ,
Same spec as my Numax charger fitted to my van, and my £20 one from china that i use in the workshop which is good for getting dead cars up and running.
That is a good call. A key advantage Lead Carbon has over standard Lead Acid is it is ok being left in a Partial State of Charge (PSOC) without harm. Usually a Lead Acid battery should be fully recharged ASAP after use to avoid ongoing damage, and I have zero doubt the battery in this thread has very rarely ever been recharged fully.Carrol Consider energy expedition plus lead carbon , they can be discharged deeper than lead acid and have 1500 charge cycles not the usual 250..only problem is they are a bit heavyer and more expensive . I have one and Jenny M has has 2 ,
Cheers, are you on the right thread? Rubbing it in a bit!Finally finished all the changes to our 12v and 240v systems.
Connected the solar up .and it works lol.
Even on a cold dull day put some power into the big boy 460ah..
Need to get out camping now..
