Okay, think I nearly have it now, you have probably explained it before and I have forgotten. I can see from the graph that when your lead Carbon bank drops it can take days to get back to full, which is what I would have expected.
The only reason the Lead Carbon is not recharging is that all the recharge current is going into the Lithium and during this period shown I am not really getting enough to recharge the Lithium fully anyway.
Maybe I will plug the van into EHU and you will see how the charging works when both battery banks are in need of charge (as of right now, Lithium is at 47%, so needs around 110Ah into it; and Lead is at a reported 85%, so needs around 45Ah into those batteries.)
Physical connections for hybrid, would you parallel the lead side then piggy back the lithium or do you treat it totally as one big bank. E.g. charge source positive one end of lead bank and negative on the other and the opposite with positive then just connect the lithium in separately? Not sure if I have explained what I mean or not lol
Charge sources flowing through lead carbon bank then piggy back lithium in and all discharge taken from lithium?
Stopping at that before I confuse myself. Will try another explanation if this is incomprehensible lol
The way I have it setup is cable up the 3 Lead Carbons in Parallel in the usual way (i.e. Balanced connections for that bank); and 2 Lithiums in Parallel in the usual way. So Lead Bank and Lithium Bank. And think of each as a single battery so you end up logically with two "batteries" - one Lead and one Lithium
You then Parallel the Lead and the Lithium - -ve to -ve, and +ve to +ve. And those common -ve and +ve connections are the Tap Off points for the "Hybrid Battery" as presented to the Camper/Motorhome. In my own case, I have Lead -ve and the Lithium -ve going to a common point, that being a BMV Shunt; and I have the Lead +ve and the Lithium +ve going to a common point, that being an Isolation Switch
So both Banks are connected to the Habitation system equally and nothing goes through one technology in order to get to the other technology - it is using the BMV Shunt and the Isolation Switch effectively as Busbars with 3 connections on each - MH Loads/Charges; Lead Battery; and Lithium Battery.
However, and this is quite an important thing, you connect a control relay, such as my VSDR Lithium Controller, between the +ve of the Lithium Bank and +ve of the Tapoff point (in my case the Isolation Switch), which allows you to (automatically) disconnect the Lithium when charged and have the charging system continue to charge the Lead.
I would also fit a suitable fuse as well on that line as all power lines should be protected. This would be the case if it were 100% Lead or 100% Lithium as well.
