no. but you might possibly have to use a different station to cope with higher weight on a lift? (and the testers have to have an appropriate license if doing a road test which a standard garage just doing up to 3.5t may not have).I have up-plated the van to 3.7 tons, has it changed the MOT class?
speed limit won't be any different if driving in the UK.No, but do you have a C1 licence, also do you realise there are different speed limits to obey?
Simon, where does this indicate that carrying out a weight uprate will change the speed limit in the UK?see this suggests different for single and dual carriageways View attachment 68056
I had a feeling you might have.I was looking at where it says in the second panel, motorhome exceeding 3050kg are limited to 50 & 60 rather than 60 & 70
He up plated it not added weight, its the same as always was.no. but you might possibly have to use a different station to cope with higher weight on a lift? (and the testers have to have an appropriate license if doing a road test which a standard garage just doing up to 3.5t may not have).
Ahh... But it COULD be heavier now, couldn't it? and the SWL load on a lift is based on what the vehicle COULD be to see if it is a safe load.He up plated it not added weight, its the same as always was.
Aparently you are the internet expert! I have just upplated my van there is no need to weigh the van for this purpose the only time the van is weighed is when you down rate thats not from trawling GOOGLE and interpretating what I see fit just a personal experience and fact! TWAT !Ahh... But it COULD be heavier now, couldn't it? and the SWL load on a lift is based on what the vehicle COULD be to see if it is a safe load.
Whch is why a garage may be happy to lift a 3500kg van on a 3500 SWL lift, but if it is 3700, the actual vehicle weight is potentially beyond the SWL. ask Scotia, he has friends who do MOTs
I think I will down rate mine to make it more saleable as I know it will comfortably weigh well under 3500kg empty. It was only when it was FULLY FULL that it weighed in at 3450 - full fuel, water, gas, bedding, clothing, food, accessories, table, chairs, people, dogs, and all the paraphernalia we all carry. Uprating it seemed a logical step, my C1 wasn’t an issue, I already had air shocks, it was cheap to do, and then saved me £100 a year on RFL.Aparently you are the internet expert! I have just upplated my van there is no need to weigh the van for this purpose the only time the van is weighed is when you down rate thats not from trawling GOOGLE and interpretating what I see fit just a personal experience and fact! TWAT !
Given that any owner could uprate again at no cost if they had the correct license, that makes great sense.I think I will down rate mine to make it more saleable as I know it will comfortably weigh well under 3500kg empty. It was only when it was FULLY FULL that it weighed in at 3450 - full fuel, water, gas, bedding, clothing, food, accessories, table, chairs, people, dogs, and all the paraphernalia we all carry. Uprating it seemed a logical step, my C1 wasn’t an issue, I already had air shocks, it was cheap to do, and then saved me £100 a year on RFL.
Don’t forget to find a weighbridge that can weigh each axle individually Dvla needs both of those to compare to each axles plated weight plus printout of the gvw weight, as a van could be under gvw but still over the plated weight of one axle usually the rear one.I’m off to get mine MOT’d later this morning, and then get it weighed again so see exactly what it currently weighs, so I can then get it downplated back to 3500kg to see if that helps to sell it sooner.
