Motorhome Servicing
Hi, we change oil/filters yearly...keeping an eye on the Boxer book for any other service needed. Earlier this year it dawned on me that the cam belt had not been changed...although less than 30k it was 10 years old. So had it replaced...apparently on time by Peugeot recommendation. That plus 4 new agilis's made it an expensive year !! Reassuring though, as now spending our third year wintering in sunnier climes. One needs to look after ones house on wheels LOL ...when you spend 4/5 months living in it !! Maja
Don't do enough miles a year to go by that so will be an annual service for fluids and filters and ALWAYS get brake fluid replaced every two years on any vehicle.
Current van (VW LT) had been sitting around for 2-3 years before bought it, so that had all filters done, fluids (engjne oil, coolant, brakes) replaced plus gearbox and rear diff oils checked. All done this time by garage so they could do a general look-over as well. Lucky I did as a brake pipe failed on the test drive which would have caught me out.
I do the simple visual bits - filters, brakes, etc, but leave other complex oily bits to the pros.
I must admit that we have a professional service with the mot and then a habitation check which includes a roof clean and a hoover out of the heater.:Sunglasses_Emoji:
Due every two years or 30k but do it annually, I do it myself though so parts only are fairly insignificant in cost terms.
Mines a 2004 Ducato 2.8 JTD and we do around 10000 miles p.a. So I do an annual service in November and sort anything wonky found in time for January MOT.
big/heavy/complex jobs get done by local Garage ( Scuddamores) who I trust.
habitation is ncluded in my service ( replaced igniter unit on the Truma space heater earlier this year)
I never pay anyone to do a job I can do myself...
k :Sunglasses_Emoji:
Ours is an old Talbot & we have only recently bought it so I have serviced it and done cambelts for my own piece of mind. I will be giving it a mini service early next year with a view of full service every year around March and MOT is October so two decent checks each year.
I get an oil change ever time it gets tested luckily I only have to pay for the oil and filter never payed labour chargers or for a test for over 30 years so cheap motoring .
Full mechanical service every 2 years
Intermediate service in between
We do about 8000 miles a year
Hab service every 2 years
New wife (every year !:Smiling_Face_with_H)
Service base vehicle annually, before MOT. Never failed, yet. Follow manufacturers schedule for oil change, and filter, every 2 yrs. Never had it serviced professionally, 'cos I don't trust them.
Had vehicle from new, and always carried out the work myself. I have far more time available, than "so called" professionals
As regards habitation service, this, in a way, is an ongoing issue, because of the problems that occur regularly. I would add, that this is down to German engineering, at it's best!
Have mine done every two years. Used to be yearly until the garage owner said the vehicle did not need a yearly service. Going to Spain in February for the first time in the van Wish me luck
Every year with Mot at our local (totally trustworthy) garage. Between £80 and £120 depending on what needs doing. Don' see the point of being a bit safer, when weighed against cost on not getting a professional to check her over. Canterbury Street, Blackburn, for those interested.
Motorhome Servicing
Do you service your motorhome just based on mileage, or do you service it every year?
Not 'or', in my view.
I reckon servicing, with at least an oil and filter change, should be every 12 months or 6000 miles, whichever comes first, on a diesel engine.
I have ours serviced in May each year ready for the big summer trip. I ended up needing a new clutch last year (£1,000, ouch!) but I was lucky because the old one would have failed while we were in France if we hadn't replaced it.
I live in a small town between Edinburgh and Falkirk and I usually pay about £150- £200 for a mechanical service and £150 for a habitation service.
Clutches dont just fail as a rull, they wear out over time, normley 150th miles +, 90% i have ever changed have been down to bad driving skills, driving with the foot on the pedal, holding it down at lights etc, or using it to control the speed.
What happens if you ride the pedal is the release bearing falls apart and the fingers on the diaphram wear thin and snap, you will notice this when the pedal hits the floor and some grinding, slipping clutches are either not adjusted or pedal riding, 1000 lashes if you fall into this catagory.
Moderen oils say 20th miles or every 2 years, me i change the van every 2 years as it dont cover many miles and oil is still almost clear.
I like to do my own servicing, once a year around this time, before the ‘season’ starts. I buy all the oil, filters etc from carparts4less and a year in advance. ie I have just bought the parts for next years service, and keep them in a box in the garage. That way, next years service is at this years prices.
Interim then Full Service on alternate years with any annoying squeaks and similar done as part of the service. Full service 10 days ago plus brakes & suspension/tyres checked (pothole hit on A34) and calipers stripped and cleaned to stop a return of the brake squeal.
Next year Interim Service will be nothing of the sort. Cam belt change, vehicle battery, probably winter tyre change, and Aircon regas as a minimum. Brunhilde has worked hard over the last year and I don't want to be posting 'Help, on way to Ferry and xyz has just fell off/seized up. Any ideas?' messages on the Forum!
For the past 12 years/60k miles along with my muckyneck pal we did all of the necessary servicing as needed, and sometimes before. I think I may need to let Merc do my new Hymer for a while until warranty runs out - that is if I can trust them to do it correctly!
