just skimmed through it, but nowhere did it state unladen weight of semi, against a diesel truck, so is the load compromised?![]()
Shop, Explore & Compare Vehicles For Sale Near You | Trucks.com
Shop New and Used Vehicles for sale near you at Trucks.com. Research, compare and save listings from our massive selection of dealer inventorieswww.trucks.com
cleantechnica.com
Payload is most certainly compromised. The Tesla is a "class 8" truck, which means GTM of 80,000 lb (36 tonnes). The 500 mile truck weighs at least 2 tonnes more than the equivalent diesel; and the diesel is rated with GTM of 44 tonnes and so a current Euro 6 diesel has a payload of at least 11 tonnes more than the Tesla.just skimmed through it, but nowhere did it state unladen weight of semi, against a diesel truck, so is the load compromised?
Tesco run over a 1000 trucks and nearly all are run at approximately 32 ton as do most supermarkets plus Amazon are the same so when you take all these trucks out of the equation you have a different landscape. Yes for general haulage electric isn’t there but general now makes up such a small percentage of haulage.Payload is most certainly compromised. The Tesla is a "class 8" truck, which means GTM of 80,000 lb (36 tonnes). The 500 mile truck weighs at least 2 tonnes more than the equivalent diesel; and the diesel is rated with GTM of 44 tonnes and so a current Euro 6 diesel has a payload of at least 11 tonnes more than the Tesla.
FWIW, I'm not against the introduction of EVs so that people can make use of them where and when they make most sense; where market forces and practicability are allowed to prevail. Warburtons is an example. There, EVs are to be used for the "last leg" to deliver into a city with stringent pollution measures. They can also make sense where the daily duty is within the range of the vehicle.Tesco run over a 1000 trucks and nearly all are run at approximately 32 ton as do most supermarkets plus Amazon are the same so when you take all these trucks out of the equation you have a different landscape. Yes for general haulage electric isn’t there but general now makes up such a small percentage of haulage.
one local garage was still selling 4 star (leaded) petrol up until a couple of years agoI think a lot will change in 9 years. Battery weight will come down and range will go up. If the government increased the 3500kg weight you can drive on a standard licence that would go some way to helping with the payload issue. Its only a ban on new sales so diesel mh will be around for a long time after that date.
Freeview channel 704 AFAICT -- all the BBC Radio channels are on Freeview. HTHI only listen in the car so will miss it, a shame it isn't on the tellybox.
If you would like to listen to any of the broadcasts but can't listen to them live, just click on the link above as Geoff suggested and you can listen on your computer or whatever you're using to post here. You could also use the BBC Sounds app. Usually the BBC has these programmes available for a year or more so there's no rush - you can listen in the background any time whilst using this website if you so choose.I can get R4 on my TV Geoff, I just have other things to do so never listen to the radio in the house unless I'm doing something in the kitchen which I avoid if at all possible.
Thanks for your input, Geoff. I guess that you're referring to this piece (or similar):From May all new car chargers will be programmed to not operate for 9 hours during the peak times each day: i.e. 8 am. to 11 am. and 4 pm. to 10 pm. -- times when most people arrive at work or return home and plug in. There will also be a random 30 minutes-at-a-time individual delay where the Grid cannot cope. There are also plans to force home owners to install third generation smart meters to permit remote switch off of high energy applications (such as car charging and home heating) or even complete disconnection of individual properties and legislation changes afoot to permit this without compensation. So it seems that the Government has at last accepted that the National Grid cannot cope with its 'all electric'
BBC R4 are broadcasting a three-part series entitled 'Electric Ride UK' on Tuesdays at 1100 which you may find interesting.
The series follows Peter Curran as he drives electric vehicles from Land's End to John o' Groats and covers all sorts of topics currently associated with the technology.
BBC Radio 4 - Electric Ride UK, Episode 1
Peter Curran travels from Land's End to John O’Groats in an electric car.www.bbc.co.uk
Colin![]()
