I can't imagine it working with just a wipe when to properly restore them needs a significant level of abrasives.
If you're worried about tit doing damage, get a cat.I assume it does something to the top layer of the Lexan, I'm more concerned about tit doing damage, I wonder if Halford sell any, they don't want you complaining instore.
I assumed that you were referring to the feathered variety; if not, I don't understand.Nope, you'll have to explain the Tom, My brain gets even more mushy after 12 noon.
Once you do a restore, it becomes an annual requirement as there is no UV Protection. Not found any way to easily reapply the UV protection.Not really convinced, I bought a polisher and did it on the van last years, but it's as bad again already.
Turtle Wax Speed Headlight Lens Restorer Kit with Ceramic Sealing Wipes | Halfords UK
Shop the latest Turtle Wax Speed Headlight Lens Restorer Kit with Ceramic Sealing Wipes at Halfords UKwww.halfords.com
You generally need to remove the top surface as it is discoloured and there is no way to recover but needs removing. It can get a bit dramaticI assume it does something to the top layer of the Lexan, I'm more concerned about tit doing damage, I wonder if Halford sell any, they don't want you complaining instore.
A coat of car 2 pack laq will do the trick.Once you do a restore, it becomes an annual requirement as there is no UV Protection. Not found any way to easily reapply the UV protection.
(I used to have a UV Spray and a UV Oven to bake the finish, but sold that over a decade ago (never used on lights anyway, just wheels).
The only real fix is to buy new headlights.
it will delay the inevitable a little. but that is all.A coat of car 2 pack laq will do the trick.
