Carrotts
Hi all. Well going over the Moho checking things out I noticed that I could not find any dial Box ......showing solar power. I know on my old Moho the solar had been connected direct to batterys and cooked them. So How do I know where the solar lead on this one goes. Tried following it but it disappears behind the panelling. With all this sunshine solar power must be going somewhere. The control panel says batterys at 100% Also there is a switch that I left on automatic which if I read it right it means that if veh battery goes low it will take power from les battery. ,,,,,!!!!!!! Did read in other threads about leaving something on. Hot water. Or fridge etc. But I am a bit loathe to leave it unattended even on the drive with things running. Any ideas or am I making Everest out of anthill. Am also thinking later of getting another 100 watt solar. Before being asked. It is a Bailey autograph 730 2015. Two 100 ah banner batterys. Do not know wattage of solar. So over to you and you and you. Thanks in advance. Also any tips on the alde hot water/ heating as this is also a newbie to me. I have also been informed not to leave it on ehu when not in use which I used to do before. Thanks again in advance. brian.
