SquirrellCook
Because my demand from 12v exceeds what my battery can deliver particularly over winter when I may also watch TV/DVDs etc. I also dont have the weight allowance on long trips to add any additional batteries. Plus having this particular charger gives me a fast charge from say an electric point in an aire for a minimum time. It all seemed like a good idea at the time.I may have missed the point somewhere, but why mains charge when you have solar? Also I'm never a bit fan of having two "smart" systems in competition against each other. Especially as they won't be smart enough to know the other exists.
Yeah we are off to head off to for a few weeks so while we were away in the New Forest I thought Id have a playNot sure if the power of the AC charger will matter that much if it is a multi-stage unit? (mine is a 120A unit).
I found the key to having the (30A) MPPT working when it was light instead of the Mains Charger was to have the voltage set slightly higher than the AC Charger (so my AC Charger is set at 14.1V and my MPPT is 14.2V (my batteries prefer a lower CV voltage than the typical AGM battery))
I would expect if you set the MPPT CV voltage to below the float of the Mains (taking account of any temp/voltage compensation) the MPPT will either never go to bulk and/or absorption, or will go through those stages really fast? (I said mine skipped from bulk to float? It is possible it DID go to an absorption phase but for such a short time the monitoring system didn't pick it up (it samples every minute))
I would normally try some different settings with my kit to see if I could help investigate further, but about to head off in a couple of days for a week or so, so need to start my trip off with full batteries.
Solar is often not enough to provide the necessary charge and need another source to provide charge. You could just as easily ask why have a split-charge system when you have solar. It is the same question.I may have missed the point somewhere, but why mains charge when you have solar? Also I'm never a bit fan of having two "smart" systems in competition against each other. Especially as they won't be smart enough to know the other exists.
I'm inclined towards SquirrelCooks view.
When in storage pesumably there's minimal load so why even bother with mains?
Whilst I may have an electric heater in the van over winter I just turn off the basic mains battery charger and leave the solar to keep both hab and van batteries topped up.
But then I don't have either a mega battery bank or a small power station on my roof!
